steering shaft
Old Feb 26, 2012 | 11:22 AM
jdchristianiii's Avatar
Default steering shaft
Is there an upgraded replacement for a 92 steering shaft. Mine is very worn, but its a poor design. I'd like to replace it with a u joint style...
Old Feb 26, 2012 | 12:47 PM
92betsy's Avatar
Google Borgeson
Old Feb 26, 2012 | 01:59 PM
chromehound's Avatar
Borgeson Steering Shafts-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
2nd and 3rd from the bottom
Old Feb 26, 2012 | 02:57 PM
lodal cummins's Avatar
I put one of these on my 92 and it did wonders. Very good investment!!!!!!!
Old Feb 26, 2012 | 06:58 PM
tower_ofpower's Avatar
I suggest getting the shaft with two u-joints and eliminate the rubber disc (rag joint). If your factory steering shaft has the splined slip joint; the splines match the borgeson joint. Cutting the steering shaft behind the rag joint plate; the ID is almost exactly the same as the OD of the splined section. Weld the splines into the factory steering shaft and follow borgeson's directions from there.
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Beelzeboss
Feb 28, 2015 07:30 AM
sweetv8s10
Oct 7, 2014 09:47 PM
