trans temp gauge
Old Feb 26, 2012 | 10:16 AM
holset cummins's Avatar
Default trans temp gauge
i am putting a glow shift trans temp gauge on my truck and i was wondering if you need any adapters on the senser to put it on my trany or can i just fund a port and what port do i use. thanks
Old Feb 26, 2012 | 12:08 PM
RAW's Avatar
RAW
Here a little something a scratched up a while back, should be able to help you out.
https://www.dieselbombers.com/dodge-...-location.html
Old Feb 26, 2012 | 11:37 PM
Russ Roth's Avatar
I want to know the very hottest the trans fluid gets so I have mine in the hot line out of the tranny to the coolers.
Old Feb 27, 2012 | 08:22 AM
Ed ke6bnl's Avatar
I have an after market pan and the sensor is in the pan... is that any good for a location ED
Old Feb 27, 2012 | 08:29 AM
RAW's Avatar
RAW
Its a very common spot, and you will be measuring the temperature of the fluid going into your transmission. Not a bad thing at all.
When I install my Aux Trans cooler, I will be installing 2 gauges. Fluid out of the transmission to the coolers will be measured by the probe supplied with the EJWA, and read on the Attitude monitor. Fluid from the coolers entering the transmission will be read on my Auto-Meter gauge. A little excessive, but then I have an idea of cooler efficiency.
Old Feb 28, 2012 | 11:00 PM
Russ Roth's Avatar
I think this is the best deal of all and intend to do the same with mine when I change pans.
Old Feb 29, 2012 | 05:16 PM
when i put the sencer on, do i need any kind of adapter or can i just srew the sencer in and be good.
Rabbitjbu
Jul 28, 2015 06:03 PM
casper83
23
Jul 27, 2015 01:53 PM
JDurks2
16
Jun 7, 2015 08:57 PM
doodieroot
May 10, 2015 11:48 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
