Rear end blues
Old Feb 25, 2012 | 08:17 PM
mitch_houser's Avatar
Default Rear end blues
Brothers 1990 F-350 Dually AT 2wd.Was tooling down hwy at 65,lost power let off and got to side of road had engine power but truck wouldnt move.Had it towed.tore into it today.Disconnected drive shaft cranked up trans would change drive shaft movement when put in differant gears.Jacked up could turn diver side wheel both directions passenger side would not move.yoke on differntial would not turn but just a hair.removed bolts to hub and after working on it for 2 hrs could not get axle to come out.We beat banged and tryed everything but it would nt turn or move any direction.We took cover off you could see gears moving and could even see splines from passenger side move.Our thoughts and any thought at this time would be welcomed.We think something broke on passenger side and by the time he got it off the road it became really hot and siezed up the bearings only a thought .We just got tired of beating on it and decided to drop the whole rear end and get another>Throw me some kind of bone on what could have happened.Thanks alot Mitch
Old Feb 26, 2012 | 05:03 PM
blacksmokeaintbroke's Avatar
not sure in brothers 90 f250 7.3 4x4 5speed,we was driving down the road and had a driver side hub bearing go out on his locked it up tight,burned off a brand new michelin,came to a dead stop,but we backed up it freed up enough to limp it 3 miles to a garage.hub bear easy fix at the garage,good luck,let us know.
Old Feb 26, 2012 | 05:49 PM
well this is no easy fix you cant get the hub off to fix any bearings the axle has to be broke if you can see the splines rotateing when the cover is off the diff.and you cant remove the axle
Old Feb 27, 2012 | 06:19 PM
one last question.Other then the 8 bolts that hold the hub in place is there anything else that the axle could be held by?????????????
Old Feb 27, 2012 | 08:54 PM
yeap there a nut in there you have to take out,advanced auto or any big parts store rents the kit.
Old Mar 1, 2012 | 07:44 PM
there is no nut to take out before u take the axles out .This axle will not come out we have put a axle puller for 450 plus size trucks and it won't come out .we got another rear end to put in sat
Old Mar 2, 2012 | 07:12 PM
DieselCrawler's Avatar
nothing else holds that shaft in. just the 8 bolts and an oring to seal it.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
chuffysplace
5.9L 24V Performance
Dec 20, 2014 11:22 PM
perk7089
Oct 11, 2014 05:03 PM
