Heater fan doesn't work, on heat but it does on others.
Old Feb 25, 2012 | 03:45 PM
BarryB's Avatar
Default Heater fan doesn't work, on heat but it does on others.
92 d250, The blower fan will work normally on A/c and defrost, but turn to heat to the floor the fan doesn't work. any ideas.
Old Feb 25, 2012 | 05:56 PM
Billy D's Avatar
Could be that door in your heater box maybe
Old Feb 25, 2012 | 06:07 PM
BarryB's Avatar
Not sure what you mean, you can hear the doors shutting and closing. But the fan actually cuts off in floor heat mode. blows in the A/c defrost mode.
Old Apr 3, 2012 | 05:01 PM
sotomo's Avatar
yea mine does the same thing im thinking that ima have to replace the compresser all together that might just be the issue
Old Apr 3, 2012 | 07:30 PM
welderboy250's Avatar
Compressor??????????? What compressor has anything to do with heat?
But to answer the original question, there are basically two possibilities. Either the electrical contacts inside the dash control (where the buttons and fan speed switch r) are bad or there is something wrong with the resistor unit for the fan speeds.
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
realtrucksrattle
Sep 20, 2015 10:24 PM
auspot
Jun 30, 2015 05:57 AM
ramrunner01
Feb 25, 2015 11:14 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
