INJECTORS! WHEN IS THE RIGHT TIME?
Old Feb 24, 2012 | 08:29 PM
65fathead's Avatar
Question INJECTORS! WHEN IS THE RIGHT TIME?
Whats up guys! When is the right time to replace the injectors or what could be some tall tale signs that possibly the injectors could be going bad? My truck has 177,xxx mile on i believe stock injector. There doesnt seem to be a problem but I'm just wondering when I should upgrade if need be (life span on injectors).
Old Feb 24, 2012 | 09:23 PM
RAW's Avatar
RAW
If there isn't a problem, then the only reason is to get better mileage while adding power. A set of RV275's, or 65HP injectors will do nothing but make the truck better in every way.
Old Feb 24, 2012 | 11:50 PM
H.R.D's Avatar
Agree with the above statement.
Glad to see you make it back on Ryan.
Old Feb 25, 2012 | 02:34 AM
2004LB7's Avatar
the right time would be just before they go bad.
if your not having any problems with them then don't worry. plenty of power can be made on stock injectors. i would wait until it is time for a new set and then look at upgrading
if you are worried that you might have problems then have a good diesel shop check it out for you first. you can also post symptoms here for help
TTipsword
Sep 28, 2015 11:48 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
