low fuel psi alert on edge
Old Feb 24, 2012 | 12:12 PM
firefighteremt's Avatar
Default low fuel psi alert on edge
Hi im having a little problem with my truck and hopefully someone can help me
I keep getting a constant low fuel psi alert from my edge juice and what will happen is when i start the truck ill get the alert and it will go away and set at normal if i let it sit and idle the fuel pressure will decrease till it hits 0 and just stay there, it also does this while im driving and i will get this alert at random times while on the road. Ive only owned the truck for 8 months and its got 164xxx on it, so im not sure what kinda problems the previous owner had or what he did to it
Old Feb 24, 2012 | 12:18 PM
You need an aftermarket lift pump. I'd recommed a FASS or Airdog.
Luke
Old Feb 24, 2012 | 12:28 PM
ok thanks luke
do i need a certain model
Old Feb 24, 2012 | 12:46 PM
pukie370's Avatar
please dont drive truck till you fix problem! or a new injection pump will be on order.
Old Feb 24, 2012 | 01:05 PM
Originally Posted by firefighteremt
ok thanks luke
Give me a call and we can discuss your options.
Luke
Old Feb 26, 2012 | 03:40 PM
sy552's Avatar
My truck was doing the same thing. It turned out to be a bad ECM. After 1 minute, the lift pump driver would turn off when watching it with a DRB. It would reset and do the exact same thing every time you started it.
Old Feb 26, 2012 | 04:23 PM
ok thanks man.... i will look into that i got a buddy who is a mechanic who is gonna look at it sometime this week and hopefully i can get it all squared away.... because i started my truck and it read 0 psi on the edge and it sat and idled for like 15 mins at 0 psi which was odd
Old Feb 26, 2012 | 05:52 PM
cmnspwr05's Avatar
Hey man throw up whats done to your truck in your sig too! That will help for future reference to give you answers quicker!
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
