Edge Comp And MAP Sensor....
Old Feb 1, 2008 | 08:50 AM
CumminsCrazed's Avatar
Default Edge Comp And MAP Sensor....
Hey guys, I know you can get more smoke with the MAP unplugged, and itll also set a P0237 code. However, is it safe to leave the MAP sensor unplugged as long as you want or will it do long term damage to engine/components.
anyone?
Last edited by CumminsCrazed; Feb 1, 2008 at 08:50 AM. Reason: Automerged Doublepost
Old Feb 1, 2008 | 08:58 AM
Whit's Avatar
Site Mascot
major soot particles in yer oil bud.....not good
soot is unburned fuel cause by a substokiemetric burn (incomplete burn)IE; not enough air
Why do ya want big smoke anyway???
Old Feb 1, 2008 | 09:05 AM
Wyatt Earp's Avatar
CC: don't fool yourself. The MAP needs to be pulled in. The pump wire doesn't need to be tapped but it helps.
If you wash by idling you will plug by removing the MAP. Either situation - $$$ to fix.
Old Feb 1, 2008 | 02:48 PM
not sayin i want big smoke, just askin if its ok, a buddy of mine asked me so i told him id ask for him, and myself while im at at
Old Feb 2, 2008 | 07:08 AM
Clunk's Avatar
Like Wyatt Earp sez, unplugging the MAP allows too much raw fuel which washes oil off the cylinder walls causing premature wear on the walls and piston rings.
The piston to cylinder wall clearance spec is a very close .0005" to .0015" and you have to protect those clearances with good operation & maintenance.
We're not talking about a loose built cheapo gasser motor.
Old Feb 2, 2008 | 09:55 AM
well isnt that amount of smoke the same as any truck with big injectors etc. Wont it do the same thing?
Old Feb 2, 2008 | 12:02 PM
Wyatt Earp's Avatar
No, not really. The big injectors send the fuel but the MAP controls the rates and mixtures with the air content. No MAP means no control = fuel only = bad news.
Old Feb 2, 2008 | 12:23 PM
hmmmm ok gotcha
Old Feb 3, 2008 | 07:00 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
I ran mine unplugged for 2 years and no problems, the benefit is the off the line power it gives you. I did plug it back in since installing the DDII's injectors. Couldn't control the smoke on the bottom end. If i get a bigger charger i'll unplug it again.
Old Feb 4, 2008 | 09:13 PM
i was told last night having it unplugged can ruin the VP.....
