Does this seem like just injectors or FICM
Old Feb 23, 2012 | 09:23 PM
1st Diesel's Avatar
Default Does this seem like just injectors or FICM
Just changed injector 7 about 2 weeks ago and had some misfire still going on. went to the mechanic and had it scanned and he brought up a screen to show each injector showing "0" (which is normal viewing on the screen) and when the misfire went it showed injector 1 and 8 going into the negatives. So my obvious guess is they need replaced. But what also caught my eye is every injector was dropping like that but only 1 and 8 were making a misfire to where you could hear it. it showed injector 7 did it once also. all of them were random and fluctuated. but 1 and 8 were the worst. So any guesses if its just each injector starting to finally go? or could it be the FICM just messing with all of them. I had two codes. One was for MAF sensor. i already know its just dirty. alot of dust and sand particles in the air down here where i am based. And the other one is P0284. Which is injector 8. But surprised i didn't see a code for injector 1 considering it was worse then 8 is. Truck just rolled 127,000. So just seems kind of odd to me. Fuel filters done about 3-4 weeks ago. Oil changed about 2 weeks ago. And added Rev-X for the first time 1 week and 1 day ago. Since fuel filters have been done about 4 weeks ago roughly i have only put about 2,000 miles on it. Use motorcraft filters. Dealer did the oil change since they owed me one so i don't know what oil they used.
Old Feb 24, 2012 | 09:14 AM
Mdub707's Avatar
You've tested the FICM already? And your batteries are newer? Sorry, I can't keep trucks straight anymore, too many forums in a day...
Old Feb 24, 2012 | 11:12 AM
1st Diesel's Avatar
Last time I tested the fickle was about a month ago. It read bad running. But I had bad batteries. Put two new 850 cca. Batteries in and pretested and it was fine. Never lower than 46.6 at the lowest.
Last time I tested the ficm* stupid autocorrect
Last edited by 1st Diesel; Feb 24, 2012 at 11:12 AM. Reason: Automerged Doublepost
Old Feb 24, 2012 | 12:15 PM
Mdub707's Avatar
It's probably just another bad injector. You might want to consider monitoring fuel pressure as well.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
