Rear end help!
Old Feb 23, 2012 | 05:59 PM
98cummins12's Avatar
Default Rear end help!
hows it going fellas. My rear end just went out.. Stuck in buying one from the junk yard or rebuilding mine. Also im not able to find the gearing on my rear end.. Only # I found on my rear end were " Dana 46293".. I need to find out the gears on it...
Old Feb 23, 2012 | 06:57 PM
tower_ofpower's Avatar
If there isn't a tag under one of the cover bolts; you're stuck pulling the cover to count teeth or looking for the engraved ratio on the ring gear.
Old Feb 28, 2012 | 12:05 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Yup Divide # or ring gear teeth by # of pinion gear teeth
Old Feb 28, 2012 | 07:31 PM
12v power !!!!'s Avatar
yep count ring teeth divide by pinion teeth, how did you break it and what did you break, ive done quite a few boosted launches and pulled over 10k and mines been fine, nice lookin truck by the way looks quite similar to mine
Old Mar 9, 2012 | 02:50 AM
12V4ME's Avatar
Default Finding your gear ratio!!!
I have a 97 dually and the info is under the hood!!! If you havent looked yet.
Hope this helps....
Old Mar 9, 2012 | 09:37 AM
daveO's Avatar
Hope this helps....
On my 98 the underhood sticker said I had 4.10's, but it didn't seem right. So I jacked up the back, had my brother turn the wheel once around while I counted the driveshaft revolutions. Turns out I had 3.55's. (Probably changed by the 1 previous owner)
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
perk7089
Oct 11, 2014 05:03 PM
