Fixing oil leaks
Old Feb 23, 2012 | 05:13 AM
davidyack's Avatar
Default Fixing oil leaks
Ive got a oil leak right now that is starting to really get on my nerves. Its leaking at the front cover and front of oil pan. It doesnt look like the front crank seal is leaking. Any good way to seal it up?
Old Feb 23, 2012 | 09:07 AM
GuyWithA24Valve's Avatar
Are you sure your vacuum pump isn't leaking too? My truck only has 66,000 miles and the vacuum pump leaks oil all over the place and makes it look like the front cover/front of pan are leaking.
Old Feb 23, 2012 | 09:26 AM
RAW's Avatar
RAW
I second that idea. Check the vacuum pump seal first. I thought I had a bad front crank seal as well, but was able to track the leak down to the vac pump to timing cover gasket.
Old Feb 23, 2012 | 10:16 AM
davidyack's Avatar
I plan to pull the front cover on sat. And see what i can do. I know its something in the cover. No oil by the power steering pump. Ive heard the oring on the vaccuum pump leaks.
Old Feb 23, 2012 | 10:18 AM
RAW's Avatar
RAW
Yes, it can leak as well. Maybe before getting too excited and pulling the cover off, pull the fan and run it that way. That is how I found my leak. You can get a solid 10 - 15 minutes running at 15000rpm before heat becomes an issue.
Old Feb 23, 2012 | 10:36 AM
davidyack's Avatar
I dont think heat will be my problem at 15000 rpm. Jk. I know im a smart @ss. Ill try that tonight. Thanks for the tip
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
