Looking for performance mods advice
Old Feb 22, 2012 | 10:47 PM
Egwin's Avatar
Default Looking for performance mods advice
I have a stock (besides K&N filter & removal of stock muffler) 1993 Dodge D350, ext. cab with 185,000 miles, Cummins 12v, auto and a completely stock 1991 (non-intercooled) Dodge D250 reg cab with 127,000 miles, Cummins 12v, auto (engine currently being removed from the truck for a swap into a Suburban).
I want to begin modifying both of these engines but would like to get some advice/suggestions from others with more experience modifying these 12 valves. I want to increase my HP/TQ while still having a dependable, long lasting engine. I would like to keep the smoke to a minimum under normal driving conditions if possible but if thats not realistic then I'll take the smoke.
I don't know if either of these have had the KDP problem fixed so I want to take care of that as well (I bought both trucks used, the '93 with 145,000 miles 7 years ago & the '91 with 126,000 miles 2 months ago).
I have a few things in mind I plan to do from reading up on these engines such as turning up the pump, fuel pin, 3200rpm spring, boost & exhaust temp gauges. I will also be adding an intercooler to the engine being swapped into the Suburban.
After reading up on injector selection & changing turbo housing or a completely new turbo I am thoroughly confused on what would work best for me to add power while still having a reliable engine. If anyone has any advice or suggestions on mods for injectors, my current turbos or if I would benefit from buying different turbos I would appreciate the help. Also if you know of any other mods in addition to my short list I already have.
I don't use my '93 to pull often (its mostly been used when I need to haul something or when I'm not on 2 wheels) & when I do its only an antique tractor or two so I rarely have much weight behind it. I'm not planning on taking it to the track or anything & not planning on having too much power for my stock auto, although if there are relativly cheap mods I can do to my transmission I'd be interested in that too.
The other engine going in the Suburban will get a little more abuse than the truck & I will be interested in sinking a little more $ into mods on this one, but like I said I would still like to have it reliable for years to come so not get to wild with it. I plan on running about 37" tires and will be doing some wheeling in it but also probably drive it as a daily driver more than my truck. I haven't decided whether I want an auto or manual but I'm planning on sinking some money in the transmission as well since it will see more abuse.
Thanks for your help
Old Feb 24, 2012 | 08:44 PM
Dustindavisusmc's Avatar
I am right about 500hp and it was fairly easy to obtain with minimal amount of smoke...
I have a super B turbo and 90lbs injectors with an M3 (manual fuel pin) 4inch down pipe to 5inch exhaust and one hell of a K&N filter.. cranked the timing on the fuel pin a little and BAM .... I have been making 500 at sea level for almost 3 years and pull heavy weight regularly.. recently moved to 6500 and had to turn my fuel down and still am pulling just under 400 to the wheels.. I run 38 15.50 20 M/T's and it hauls *** boy!
If I stand on it in 3rd gear with a little water on the ground the truck will walk on me.
I am editing this because I must say I wasnt quite 500hp high 400's though.
Old Feb 25, 2012 | 12:15 PM
moparbubbabt59l's Avatar
500hp? Off of those mods?
Sent from my DROIDX
Old Feb 25, 2012 | 12:27 PM
High end of 400 ... no bs... I know guys like like to talk bs... I have nothing to prove to any of you.. there is a dyno run at 360ish on youtube before turbo and fuel pin... look under fummins
Old Feb 25, 2012 | 12:54 PM
I can believe 300ish was a correction factor used on the dyno?
Sent from my DROIDX
Old Feb 25, 2012 | 01:02 PM
http://www.1stgen.org/viewtopic.php?t=961
Sent from my DROIDX
Old Feb 25, 2012 | 01:31 PM
But for the op id recommend a 366 spring denny t fuel pin m&h dynamic timing spacer low pressure piston lp coolertubz gauges pyro boost fuel ect. Adjust you starwheel and screws.
Sent from my DROIDX
Old Feb 25, 2012 | 02:38 PM
I think I might now some of those guys, I am originally from Moses Lake Wa...
on another note I am going to set some times up for some runs this week or next depending on what the dyno schedule is and post a printout...
brianj2077
Aug 4, 2015 09:06 PM
Spaky6.0mudder
Aug 3, 2015 08:54 PM
GHETTO_PIZZA
Apr 9, 2015 10:48 AM
twm011
Feb 24, 2015 09:11 AM
rtbcoop
Dec 30, 2014 02:13 AM
