c_rapps
Old Feb 22, 2012 | 10:44 PM
c_rapps's Avatar
Default c_rapps
I need some advice, I am trying to change the belt on a 2005 dodge diesel and I cant get the belt past the tube that goes up from the bottom of the radiator. Is there a trick to this? I have put the belt over the blades about 20 times today and it keeps getting stuck behind that tube!!
Thanks for any help
Old Feb 23, 2012 | 06:47 AM
steved's Avatar
I didn't think you needed to pull it over the fan blades? The toughest point for me is getting it off the crank pulley. You should be able to pop the belt loose of the tensioner and almost pull it out the bottom of the assembly.
