no start
Old Feb 21, 2012 | 02:34 PM
dieselpowertv89's Avatar
Default no start
Alright I have a bone stock 2000 dodge cummins that won't start. believe I have no fuel past injection pump. There are zero codes. All fuses and relays are good. Truck turns over but wont start.
Old Feb 21, 2012 | 02:45 PM
vineyardm's Avatar
Have you cracked lines at injectors to confirm that the Injector Pump is sending fuel to injectors?
Do you have fuel pressure gauge to monitor Lift Pump pressure? (If yes - what is the pressure when you turn key to start briefly and LP is operating? If No - WHY NOT??)
Old Feb 22, 2012 | 04:41 AM
globalwarmingcontributor's Avatar
yep, crack the lines and make sure your getting fuel past IP... maybe it could be the lift pump.
Old Feb 27, 2012 | 01:26 PM
Update I have half a tank and no fuel anywhere wtf about two weeks ago I installed a new rapitor frrp I can hear it run wondering if that's the problem
Old Feb 27, 2012 | 10:55 PM
ya it might be... anyway u can test it?
Old Nov 12, 2012 | 10:54 AM
Lee Young's Avatar
just wondering if you resolved this problem as I am having same problem. have fuel to injector pump but none going to injectors. Also have low volume from the transfer pump.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
