Engine rebuild
Old Feb 22, 2012 | 09:05 AM
harry22's Avatar
Default Engine rebuild
Im looking at buying this kit. 5.9L Cummins B Series Engine Rebuild Overhaul Kit
I have a question about the pistons in the kit. What is the reasoning for goin to the large bowl piston? What should i do? This is for the truck in my sig. Thanks for any insight or pointers!!
Im wondering about the piston because im worried about the spray angle of my injectors vs. the piston bowl. Just want to make sure im not doin this again for a long time
Old Feb 22, 2012 | 11:03 AM
turbo2332's Avatar
marine bowl pistons are for the 155* injector pattern also some pre intercooler ingines. most everything else including your engine came factory with 145* injector spray pattern and a smaller bowl piston.
Old Feb 22, 2012 | 07:30 PM
tower_ofpower's Avatar
Larger bowl slightly reduces the compression ratio, not enough to affect anything from what I hear. Some recommend it just because of the "I can cram more air in there" theory
Old Feb 23, 2012 | 01:21 PM
harry22's Avatar
Well after its rebuilt i dont plan on going for anymore performance than what has already been done to it. I think i'll go with the stock pistons then after its broke in, re-tune it to the way it is now. The reason im rebuilding it is because it washed the cylinders down and took out the cross hatching. I think i want to send the pump out to get looked over but im not sure what i should do with the injectors. Send them with the pump or send them back to SDX to have them checked out?
burndiesel
10
Feb 7, 2023 01:15 AM
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
coryfast
Jul 23, 2015 09:00 AM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
