Cross Oversteering?
Old Feb 21, 2012 | 01:10 PM
450sandridr's Avatar
Default Cross Oversteering?
whos done it what parts
which pitman arm or steering box
now that my 1st gen4x4 has a p pump n twins i need the steering to be right
Old Feb 21, 2012 | 01:36 PM
tower_ofpower's Avatar
4wdfactory.com
They have the kit you need, comes with drop pitman, drag link, tie rods, and kingpin cap. Along with all D60 kingpin repair parts you need. Polyperformance.com has bronze upper bushings for the D60 to replace the teflons. I did a write up on mine; search the aftermarket section. It's in there somewhere. You'll want to either make; or invest in a steering brace. These frames weren't meant to be torsional tolerant. The steering box will flex like mad.
Old Feb 21, 2012 | 01:51 PM
i already have a brace on order and will machine my own dra link and tie rod just curious whichsteering box or pitman arm to use
Old Feb 21, 2012 | 03:14 PM
Factory steering box will work, that same site sells the pitman arm separately. You just install the pitman arm so it's parallel to the frame. You are aware the box is moved to the 2wd holes in the frame and you ditch the 4wd bracket right? There's an aftermarket steering box that's supposed to be **** but I can't remember who makes it. Not necessary tho.
