Getting hot while towing.
Old Feb 21, 2012 | 11:44 AM
skav's Avatar
Default Getting hot while towing.
Last summer, I towed our toy hauler and my coolant temps would get very hot (it would overheat if I stayed in it).
I swapped the big injectors to II 85hp, and it's a lot better,
But will still get hot on a grade. I also pulled the rad and cleaned it. I flushed it, and rust came out of the lower hose.
Seems like when egts are over 1100 for any length of time, the coolant temps will climb.
Any ideas?
Old Feb 21, 2012 | 12:56 PM
Oil Igniter's Avatar
Ok couple of ideas, first would be a thermostat change, there should be a high flow model you can get or just a fresh one. Second is I run my mix at about four to one. 1 part antifreeze 4 parts distilled water. Water has much better cooling properties. Third would be to make sure you have good air flow through your A/C condenser and through your intercooler because they are both ahead of the rad. So if air can't get through those then it wound make it to the rad. Fourth is to not run your A/C when you know you are about to pull hard. Last I think would be to make sure the engine is breathing well. I didn't look at your sig but air intake and a free flowing exhaust helps everything. Im no Dr but these are just some things i have done that seemed to help.
Old Feb 21, 2012 | 01:14 PM
skav's Avatar
I'll check the AC condenser. The IC is a Spearco replacement. I have an open 5" AFE and a 4" down, then 5" out the back.
Do you have any info on the high flow tstat? Part number or anything? I just replaced the fan clutch at the beginning of summer. I'm running premixed coolant now, so 3:1 makes sense. I'll give that a try.
I tried looking for a larger replacement rad, but didn't find one.
Would excessive blow by cause overheating?
I keep boost under 30psi when pulling a big grade.
I should also mention that I'm running a PP and the Smarty is on level 4 now. I didn't run the pp over summer, and the Smarty was on level 2.
This sucks to test, because the truck will not get hot unless I am towing.
Thanks for the advise.
Old Feb 21, 2012 | 08:34 PM
skav's Avatar
Any other suggestions on this topic?
Old Feb 22, 2012 | 01:15 AM
pukie370's Avatar
how many miles on radiator. from my experience most cummins are good to 200k then radiator gest pluged and cooling eficiencey goes down. I just pulled my radiator out looked good and no leakes, put new one in and bam temp never moves now. ther is a extra large radiator out ther also. and i forgot to add if you have auto with sliping converter it will kill your temps!
Old Feb 22, 2012 | 01:24 AM
01quadcab's Avatar
is it a cummins or a ford?
Old Feb 22, 2012 | 07:49 AM
skav's Avatar
It's interesting that you mentioned the rads plugging. When I pulled mine, I stuck the hose in the top to rinse it out, and a lot of rusty sludge came out the bottom. I wonder if it is plugged. It has about 165k on the rad.
Do you have any info in the extra large rad? I call a couple places and only found a stock replacement. I'd like to swap to a high flow tstat and extra large rad.
Old Feb 22, 2012 | 07:51 AM
skav's Avatar
This is on my 98.5 Dodge. I should update my sig.
Old Feb 22, 2012 | 08:24 AM
lunk's Avatar
radiator is plugged get a new one genesis auto has them for 130 i think both my 01's did that one with 135000 and the othere 156000
camp9
Mar 25, 2017 07:40 AM
drsparkman
Nov 4, 2015 10:32 AM
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
Sep 29, 2014 12:40 PM
