I Need A VP44 That Flows More Fuel
theres actully a very reputible source for the pump around! I can get you in contact with him! Or I can help you! The pumps themselves are not proven, nor the power that was made on the truck mentioned, but its still hopefull! Theres actully some really cool progress coming from the shop that makes the monster! The Stage 3 Requires a special Injector Tip (Same Body as Factory) . There made from a larger injector and Milled down for size and then EDM honed! In all honesty, You'll have all the fuel you need with a SO pump! Be sure not to get talked into a Hot rod or Monster pump by a smooth talker unless you REALLY need one...Chances are you do not!
L
L
