codes
Old Feb 20, 2012 | 07:49 AM
kd8dzh's Avatar
Default codes
Have codes p 0674 and p2291 in my 06 6.0 250. Got. the doses from the edge programmer
Old Feb 20, 2012 | 08:11 AM
Mdub707's Avatar
P0674 is glow plug #4 (from the front of the engine facing rearward, second cylinder back, on drivers side)
P02291 ICP is too low. Is the truck running/starting ok?
Old Feb 20, 2012 | 02:34 PM
kd8dzh's Avatar
It is hard to start. Runs good
i knew the glow plug was bad has been for a few months.i don't think the other code has been on very long. a few days maybe. wha would i need to do to get it fixed?
Old Feb 20, 2012 | 03:02 PM
Mdub707's Avatar
Tough to say right now. Try unplugging the ICP sensor and starting it, see if it starts any easier. It's the sensor right in the passenger side valve cover, passes right through.
Do you have access to a scanner of some sort?
Can your CTS monitor some PID's on the truck? Like can you watch ICP actual and ICP desired with that? I'm not really sure what they're capable of...
Old Feb 21, 2012 | 07:12 AM
kd8dzh's Avatar
i have been watching the ficm voltage and battery volts. i will try that and see if it helps. ficm says 46 -48volts.
Unplugged it and it started right up
Would it be ok to run it with out the icp hooked up?it does start when it is unplugged. I would have to jump it to get it started when it was plugged up.
started the truck this morning and had to plug the icp back up to start it(temp outside around 30degrees) when it get warm have to unplug it. do i need to get a new one
Old Feb 21, 2012 | 08:32 AM
Mdub707's Avatar
I would say so. Typically when you unplug it, the PCM just defaults to some standard settings allowing the truck to start. That's odd it wont start cold without it though. At this point, I would probably replace it if it was me, but I hate telling people to replace parts without KNOWING what needs replacing. If you can't monitor anything we're just basically guessing anyways.
Old Feb 21, 2012 | 06:33 PM
kd8dzh's Avatar
[/size][/color]
i have problems now.
had the truck towed home, will not start. i have one of the batteries on charge. (if it will charge). just got them about a month ago. next thing i do is check the ficm. i tried unplugging the icp and nothing. have to have this for work and don't have alot of money to work with as work has been slow.
Old Feb 22, 2012 | 07:09 AM
Mdub707's Avatar
Are you getting smoke out of the exhaust when you crank it to start?
How far are you from snowshoe WV?
Old Feb 22, 2012 | 07:58 AM
kd8dzh's Avatar
it started this morning. i don't think it was smokeing. i am about 4 hours from snowshoe.i charged the battery on a low setting last night. i am goint to est the ficm today. trying to rule out other things before i tear the motor apart to fix hpop system. i am sure that is part of the problem.i think it wouldn't start because the batteries were to low to. tried to jump it but that didn't help
Old Feb 22, 2012 | 08:27 AM
Mdub707's Avatar
Get your batteries charged good, test the FICM and then let us know what happens. If you crank the truck and it's not starting, check to see if there is any smoke. Would really help if we could get a scanner on this thing.
Holderdown performance is in Snowshoe, real good group of guys to deal with.
