OIL IN MY EXHAUST!!!!
Old Feb 20, 2012 | 07:19 AM
antnybeatu's Avatar
ATTN OIL IN MY EXHAUST!!!!
so in an earlier post a couple of Days ago i Posted about white smoke at idle or take off....
Well ive done a little invetingating and found that i am burning oil in my exhaust! enough that when i swipe my finger across the tip, its wet, really wet... So im assuming Turbo seals are going out.... How long do i have? Im 700 miles from home and its appearently been leaking for sometime now and its gotten bad enough to actually get my attention, it pretty much constantly smoking right now unless im doing the speed limit..... which means its burning it off at a rate that i dont notice it.... any suggestions or advice would help... I am a new diesel owner and really dont know **** about these things.....
Thanks guys for all your help!
Old Feb 20, 2012 | 07:31 AM
Mdub707's Avatar
How long do you have? Til when?
My cousin just had this happen on a road trip in his 06. He had added 3 quarts of oil already and finally started losing serious power, started throwing turbo codes, mostly P0299 (turbo underboost). He was still able to limp it to a shop to get it fixed, but I'd fix the issue sooner than later.
If you just want another stock turbo, check the powerstroke forums for a used one, usually can get one between $250 and $400, depending on year and mileage.
If you want new, get a new powermax from Garrett. It's a direct bolt in replacement, spools like stock, flows a little more up top, and is all around a great turbo. They run about $1200 new.
Old Feb 20, 2012 | 07:36 AM
antnybeatu's Avatar
i just want to know if i can make it back 700 miles i actually have another stock turbo in my barn at the house, guess i need to check my oil then... im not really recognizing any substantial powerloss, but thats not to say that i wont on the way home... if it goes out completely im assuming i wont be able to drive this beast without the turbo....
Old Feb 20, 2012 | 08:09 AM
Mdub707's Avatar
Exactly. I would probably try to drive it myself. Can't guarantee it'll make the trip, but I would certainly try it.
Old Feb 20, 2012 | 08:23 AM
antnybeatu's Avatar
Thanks for the info!! You've been a major help
avatardvr
18
Aug 8, 2019 12:38 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
lacrab
Sep 10, 2015 01:17 AM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
