overdrive
Old Feb 19, 2012 | 04:39 PM
jdchristianiii's Avatar
Default overdrive
I have a 92 W250 cummins with an auto trans... I hate an automatic, but I got the truck for a song it is decent daily drive save for the overdrive not functioning. The button on the dash works properly(at least judging by the light). I am repairing the speedo gear reduction box, but have the sensor direct to t-case for now. 40mph on speedo is actually 55mpg roadspeed. This truck has a TV cable set up and not a tps... OD is not kicking in at all, but I do have "lock-up" on the convertor... Any info would be great. Feel free to txt me- 540 624 2598. Thanks much!!! JD Christian, III
Sorry for any mistypes! I am using a black berry for this and I have big hands.
Last edited by jdchristianiii; Feb 19, 2012 at 04:39 PM. Reason: Automerged Doublepost
Old Feb 19, 2012 | 08:22 PM
Gas's Avatar
Gas
You have a lock-up torque convertor in a 92? Did the previous owner swap that in? Sounds like you need a new tps.
Old Feb 19, 2012 | 09:11 PM
Yes, it is an A518 which is a lockup convertor overdrive transmission... This truck does not have a tps! It is a TV cable setup... I have been around transmissions a lot for 10 year working with my grandfather who has been building auto-trans's since 1955. I have never done a 1st gen cummins auto though. I believe it needs a TV cable because its adjustment will not come into range.
I recently goit this truck 'for a song'... It is beat up bad but the maintenance has has been kept up for at least the past 3 years by me. The lady who was 2nd owner had me keeping that up... Engine is good and trans is good. Not just be sight and feel, but I had fluid samples analyzed... Btw, ford has run a lock up convert since 87... I am a ford guy, so I know them, but dodge is new to me. I have worked on 5.9s for a while but not in a pickup...
Last edited by jdchristianiii; Feb 19, 2012 at 09:11 PM. Reason: Automerged Doublepost
Old Feb 19, 2012 | 10:14 PM
sweetv8s10's Avatar
The A518 does not have a lockup converter and it uses a tps and tv cable.
Old Feb 19, 2012 | 11:20 PM
NadirPoint's Avatar
This
94/46RH was the 1st year for the lockup Tq converter.
Old Feb 20, 2012 | 12:10 AM
BC847's Avatar
Originally Posted by NadirPoint
This
94/47RH.
Old Feb 20, 2012 | 12:13 AM
NadirPoint's Avatar
Ahh yes... So is 46RH another name for the A518?
Glad to see you still hanging around here, David!
Old Feb 20, 2012 | 01:50 AM
peobryant's Avatar
Yep, 46rh is the same thing as an A518.
That truck looks awfully familiar. You wouldn't happen to be on 1stgen.org as "Ace" would you?
Old Feb 20, 2012 | 02:16 AM
Where the heck is the tps?! I cannot find it anywhere on the throttle linkage (or a plug that is not plugged in where it could have been)
Old Feb 20, 2012 | 02:21 AM
NadirPoint's Avatar
Oh no, I've been exposed as the former Ace - from there and other places.
So many web forums, so little time...
