Egt's
Old Feb 19, 2012 | 12:51 AM
lodal cummins's Avatar
Default Egt's
So I installed pyro m3 pin & timing spacer. Only see 900 on pyro. Bahf and 3" straight pipe. Why so low as I can hit 1200 in the blink of a eye on the 96 I know the p pump flows more fuel and the injectors are75 hp. Is the difference in the pump and the 18cm exhaust for the low temps? By the way this is a 92 5 speed. Thanks!
Old Feb 19, 2012 | 07:33 AM
Cummins12Club's Avatar
where is your pyro probe in both trucks? if your 2nd gen is in the exauhst manifold, and your first gen is in the down pipe then theirs your reading difference,
Old Feb 19, 2012 | 11:09 AM
Nope both in exhaust manifold
Old Feb 19, 2012 | 01:19 PM
ricet07's Avatar
Just sounds like the 96 is fueling pretty hard, I wouldnt complain about 900 in the 92 but your injectors and 100 plate are making the difference I would say.
Old Feb 19, 2012 | 01:49 PM
cougar's Avatar
Check the boost line to the AFC housing. With the M3, you should be higher than 900°. Also where is your star wheel set?
Old Feb 19, 2012 | 02:12 PM
Starwheel is like 3/4 way down and boost line is fine off the manifold to top of pump. Truck runs great and I'd rather be low than high just wonder why the big difference at idle pyro is like 225
On a side note after doing timing spacer I used hand pump on side of lift pump about 20 times and lever never got pressure on it. I planned on doing LP piston lift pump next anyways.
Last edited by lodal cummins; Feb 19, 2012 at 02:12 PM. Reason: Automerged Doublepost
Old Feb 19, 2012 | 02:33 PM
sweetv8s10's Avatar
My lift pump done the same thing come to find out the rod that pumps the fuel came undone and I didnt know it I just changed it and went on.
Old Feb 19, 2012 | 04:20 PM
cougar's Avatar
True, low EGT is better than melting piston, but this seems unusually low. What kind of boost numbers are you seeing?
On the lift pump, if your lever in on top of the cam lobe the hand primer does nothing. The piston pump doesn't have that problem. Just make sure it's the low pressure pump unless you add a regulator.
PS; Higher lift pump pressure will give you more case pressure negating the usefulness of the timing spacer unless you can find a stronger spring to overcome the extra pressure. A nice catch 22.
Notdaddysmoney
11
Oct 23, 2015 12:52 AM
CumminsCoalRoller24/7
May 25, 2015 09:04 PM
Moparts345
May 24, 2015 09:35 AM
Curry
Apr 20, 2015 04:04 AM
TheDirtyDozen
Nov 16, 2014 02:56 PM
