Part Priority Help!!
Old Feb 17, 2012 | 10:13 PM
Hoogie206's Avatar
Default Part Priority Help!!
Hey guys, im relatively new to the site. and have been searching for how to figure out what part to buy next.
so far i have installed the denny t stage 2, BHAF/ cold air, and 3.2k rpm spring, along with pyro and boost gauges,pump turned up 1 turn, and star wheel maxed.
next on my list of things are things like turbo upgrades (compressor and exhaust on my H1C)
OR
Possibly an HX35 (found one on CL for 275)
which will supply more air without over doing it?
which would you guys suggest?
other plans include
sdx 5X14 injectors,
3pc manifold
Which order would you guys suggest i do these upgrades? and are there any others that you would suggest?
im looking to make my truck a powerful yet fuel efficient daily driver and toy hauler.
thanks so much
Sam
Old Feb 18, 2012 | 12:06 AM
ricet07's Avatar
I would upgrade your turbo first, meaning get a bigger one, dont bother with building your H1C if you plan on running bigger sticks. Eventhough your truck is intercooled, it wasn't originally so it has the bigger 9mm injectors vs the 7's on the IC trucks. You can get a decent amount of fuel through the stockers for now. Once you get a bigger turbo then start looking into some 5x12 or 5x14's. The HX35 would be a decent upgrade and that is a good price if it is a good turbo. Valve springs would be good as you start pumping more boost.
Old Feb 18, 2012 | 07:16 AM
turbo2332's Avatar
ditto on the turbo might save some pennies and look for a used 62 and dont go huge on the injectors 5x.012's are plenty! might look into a lift pump or maybe just even a fuel pressure gauge to make sure you are keeping plenty of fuel to the VE i think 14psi is max.
Old Feb 18, 2012 | 09:43 PM
Hoogie206's Avatar
What would the 62 be? hx35s are 57? what is the hx40 compressor size?
oh and what size would you guys suggest for the exhaust housing? 16cm?
Old Feb 19, 2012 | 06:49 AM
turbo2332's Avatar
i would recomend a 14cm housing
H1C 50 or 54/60/18 or 21
HX35/WH1C 56/58/12 52-60 lbs/min
HX35/40 60/58/12 in between these two
HX40 60/65/16 60-71 lbs/min
Super b 57/65/14
Super B special 64/71/14
HE351 60/60/9
HE351VE 62/65/4-26? variable
HE341 54/58/9
3000 59/65/ 65 lbs/min
4000 63/70/ 75 lbs/min
5000 71/74/ 95 lbs/min
Bslamb
Jeep Liberty
Aug 10, 2015 04:28 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Mar 4, 2015 08:20 AM
jrsavoie
Feb 6, 2015 09:44 PM
countryboy040993
10
Nov 16, 2014 08:21 PM
