pyro install
Old Feb 17, 2012 | 11:49 AM
oldblue12v's Avatar
Default pyro install
Whats the best way step by step to set up a pyro gauge in a 1st gen non intercooled 12v?
Old Feb 17, 2012 | 09:13 PM
db Zac's Avatar
There is a step by step YouTube video out there
Old Feb 18, 2012 | 12:09 AM
ricet07's Avatar
Might be something in the sticky too, havent looked in there for awhile myself.
Old Feb 18, 2012 | 02:39 PM
swampdonky311's Avatar
drill and tap into your down pipeand just add 200 degrees in your head when driving then run your lie into your cab to your gage and find the wire for your running lights and wire that into your gauge so it lights up all pretty like at night time
Old Feb 18, 2012 | 03:40 PM
db Zac's Avatar
It's a progressive increase. So it may be 200, at 1000 deg but 350 at 1200
Sent from my Galaxy Nexus using Tapatalk
Old Feb 18, 2012 | 07:48 PM
sweetv8s10's Avatar
I would put it pre turbo.
Old Feb 18, 2012 | 08:46 PM
ricet07's Avatar
x2 pre turbo is more accurate. Not that hard just drill off center of the manifold and stick a little magnet in there to get as many shavings out as possible then tap it with a little grease on the tap.
Old Feb 18, 2012 | 08:56 PM
NadirPoint's Avatar
Default This Would Be What We Call A Freudian Slip:
...then run your lie into your cab to your gage...
Bolding mine.
Old Feb 19, 2012 | 02:02 PM
cougar's Avatar
I have both pre and post. Never seen more than 200 difference. But, if you really want to be pit nikky #6 is the hottest due to less air making it to that cylinder. Put your probe in the runner as close to the cylinder head as possible.
Old Feb 19, 2012 | 04:45 PM
have any of you with pre turbo gauges had any problems with the tip of the probe getting boken up and sucked into turbo?
