to much boost!!!
Old Feb 15, 2012 | 07:43 PM
Al31031's Avatar
Default to much boost!!!
okay hopefully someone can help me. I have a boost elbow on my truck which is adjusted all the way out and still builds like 55psi could it be that the wg isnt working is there anyway to check it? thank you
Old Feb 15, 2012 | 08:01 PM
monster12valve's Avatar
wg def isnt working
Old Feb 15, 2012 | 09:40 PM
nasty 2005's Avatar
with 024dv's, 140ddp's, no plate, 4k gsk, what the hell do you expect a stock charger to do? I would bet it is working fine there is just way to much fuel for that poor charger get that off of your truck a.s.a.p. because at 55 psi it won't last long. What does your egt gauge do peg out instantly? My pump is set up similar to that with 191's and a 62/74/14 turbo and I can easily turn 55 psi and my egt's will peg the gauge at 1600 quite rapidly!
Old Feb 16, 2012 | 09:13 AM
Al31031's Avatar
as weird as this sounds my egt's never go above 1400 but shouldnt the waste gate work anyway?
Old Feb 16, 2012 | 01:13 PM
nasty 2005's Avatar
It probably is it is just alot of fuel for it. Just unhook the line and blow air through it and watch the gate and see if it moves.
Old Feb 16, 2012 | 01:31 PM
turbo2332's Avatar
be carful with the air, super easy to check though. and 55psi thats close to KABOOM. my guess is a stuck wastegate. i could turn my stocker down to bout where ever i wanted it with my elbow no problems.
Old Feb 16, 2012 | 02:30 PM
BOOSTJUNKIE's Avatar
Wastegate is probably functioning but with your mods it's just being overcome by the huge amounts of exhaust pressure. Get a bigger turbo ASAP. I only have relatively mild mods on my 24v but the wastegate is already on the brink of too much as I hit 32psi with no boost elbow/control
Banks Monster Ram inlet-BHAF-Pensecola 50hp injectors-Raptor 150 lift pump-GDP Big lines-Banks heater delete-Smarty-BD low pressure light........for now
Old Feb 16, 2012 | 07:04 PM
turbo2332's Avatar
no way you can get 55 out of it unless something is stuck shut or not working.
Old Feb 16, 2012 | 09:27 PM
Al31031's Avatar
well thank you tomorrow ill blow some air through there if it is stuck whats the best way to free it up?
Old Feb 17, 2012 | 12:13 AM
tower_ofpower's Avatar
Lots of penetrating fluid if the shaft is set up in the housing. Then plenty of time working the wg open/closed to free it up.
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
