hard starting
Old Feb 14, 2012 | 06:25 PM
Sawman's Avatar
Default hard starting
I have the truck in my signature, if truck sets over night or a long time threw the day, it will crank but wont start. i have noticed that when I turn key on and wait to start light has a delay, it never use to do this. also when truck fails to start it seems like raptor is running for longer than it should. Once truck starts you can turn off and it will start back like it should. I pulled cross over tubes and replaced o rings last week end thinking it was sucking air, but no luck. I have thought it might be intake heater but it seems to be working as it should. Help please, thanks
Old Feb 14, 2012 | 08:10 PM
Whit's Avatar
Site Mascot
its a fuel issue..................getting air somewhere
Old Feb 16, 2012 | 08:23 AM
globalwarmingcontributor's Avatar
check the fuel lines coming off the tank to the raptor, and then raptor to the injector pump, or wherever it goes after raptor 100.. also check the injector lines from IP to blcock. could be a loose fuel line.. maybe?! just making a few suggestions.
also ... with truck running start cracking injector lines,.. make sure you are getting fuel to each injector. and not just blowing air.
Last edited by globalwarmingcontributor; Feb 16, 2012 at 08:23 AM. Reason: Automerged Doublepost
Old Feb 16, 2012 | 07:59 PM
Sawman's Avatar
thanks for the input, we have went over it time and time again. It seems like something electrical, am not getting any power to grid heater, and dash lights are working odd. The wait to start light will come on 20 sec after key is on, all other lights just work randomly. wish i could find what sends power to grid heater seleniods but got tired of messing with it tonight
Old Feb 16, 2012 | 08:35 PM
hydroshok's Avatar
Did you check the return valve from the VP 44? You may have two unrelated issues, but the power to the solenoids comes off the driver's battery. They are located on the fender below the battery. Your connections may be corroded.
Excursion73
Oct 27, 2015 05:21 PM
Easton18t
Jul 30, 2015 02:06 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
