flex plate
anyone know where i can get the best buy on a good flexplate and what would be best one to go with.. i plan on doing compounds later and bigger injectors so i do plan putting more power down then what i am now .. will i have to buy spacer with going with aftermarket flexplate from what i gather a thicker flex plate pushes the converter back more to where it might rub the pump seal ? any info will be helpful guys ..
I have a bd didn't have any issues with it moving the converter. The ring gear did fall off but we fixed that. it was only pressed on. now it's tack welded on at all 6 converter bolts to keep it balanced. a lot of guys just laminate 2 together.
cdetterer
Jan 22, 2015 08:38 PM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
