She's showin' her age....
Old Feb 12, 2012 | 09:21 PM
geddy's uncle's Avatar
Default She's showin' her age....
Guys, what's a U-joint or a carrier bearing sound like when it's going? I've got a driveline noise that's rolling-related, and sounds like a jackhammer @ about 20mph.
PLEEEEZE let it be a cheap noise.
Old Feb 12, 2012 | 09:44 PM
NadirPoint's Avatar
I'm wondering too, because I have a little tick, tick, tick sound mostly noticed coasting down to a stop. It increases or decreases in tempo with ground speed. I'm thinking u-joint, but really don't know.
I will start taking it apart before it gets to the jackhammer level!
Old Feb 12, 2012 | 09:52 PM
mysterync's Avatar
Axle joints at the wheels?
Sent from my DROID BIONIC using Tapatalk
Old Feb 12, 2012 | 10:04 PM
NadirPoint's Avatar
I can't imagine what else it could be.
I bet Geddy's is a carrier bearing. Or maybe the transmission is about to come apart in some spectacular way.
Geddy, does the noise change at all go or away if you shift into neutral and let it coast?
Old Feb 14, 2012 | 11:19 PM
motion-related. in-gear/out-of-gear...if it's moving, it's making noise. I'm off tomorrow, so, I can go get it investigated. I'm in an apartment, now, so I no longer have a garage. My limited skills are even more limited now.
Old Feb 15, 2012 | 09:41 AM
ricet07's Avatar
U joint for sure, just what one . needle bearings are shot and are click/ticking.
Check your driveshaft center support for play in the bearing otherwise a horrible u joint.
Old Feb 15, 2012 | 11:23 AM
I'm not that lucky. up on lift, turn a rear wheel. rear diff goes "clunk clunk clunk"... that won't be cheap
Old Feb 15, 2012 | 08:00 PM
monster12valve's Avatar
Old Feb 15, 2012 | 08:36 PM
busted 3 teeth off of the pinion, chewed the ring gear a little. gonna fix it to make saleable, and let'er go to a good home.
Old Feb 15, 2012 | 09:13 PM
ricet07's Avatar
That hurts. Have another truck lined up?
