12cm turbine housing
Old Feb 12, 2012 | 04:25 PM
Ac6080's Avatar
Default 12cm turbine housing
So i have a WH1C turbo on my 1994 12v and i am wondering what the benifits would be of upgrading to a 12cm exhaust housing. I know i would notice alot quicker spool up, but would i have a lower max boost, or would i notice alot higher egts?
Old Feb 12, 2012 | 05:50 PM
cummin_un_glued's Avatar
FormerVendor
quicker spool, more boost, tuned right should lower egts since you have more boost, depends on pump and wastegate tuning tho
Old Feb 13, 2012 | 08:19 AM
gwhammy's Avatar
If it is a wh1c it already has the 12cm wastegated housing. If it's a h1c it's the non wastegated turbo. The wastegated turbo will spool alot faster.
Old Feb 13, 2012 | 12:07 PM
turbo2332's Avatar
ditto its already a 12 and no matter what you do with it it will be choked out in the higher rpms.
Old Feb 13, 2012 | 08:01 PM
Ac6080's Avatar
ok, so i already have a 12cm housing, but what do you mean it will be choked out at higher rpms? and should i get a better wastegate while im at it since mine is broken anyway?
Old Feb 13, 2012 | 08:33 PM
NadirPoint's Avatar
How much boost is it making now?
Old Feb 13, 2012 | 08:50 PM
turbo2332's Avatar
the turbo is just small. it cant move big amounts of air in or out. great little turbo but its little so its choky in the higher rpms it cant breathe well
jeffersonl
Nov 15, 2015 07:35 PM
scottw1513
May 2, 2015 08:16 AM
D-350 dually
Apr 11, 2015 11:38 PM
jeffersonl
Oct 25, 2014 06:46 AM
Spiderman
Oct 6, 2014 09:52 AM
