Intermittent Problem
Old Feb 12, 2012 | 02:36 PM
Mud digger's Avatar
Default Intermittent Problem
From time to time when idling the little battery light on my dash lights up, then when you give the truck rpm if goes off. Sometimes it goes off at 900rpm sometimes it goes off at around 1500 rpm. Not every time it's idling does this happen, very intermittent. I was thinking alternator or regulator but not sure because it doesn't always do it. Has anyone else encountered this problem. The truck is a 04 6.0 with no mods. Thanks
Old Feb 12, 2012 | 02:43 PM
fatboyslim's Avatar
i had this problem with my 96 4 runner. turned out the alternator was over charging. it was on constantly after a while before i parked it. i was warned that it could start taking its toll on the electrical system eventually.
Old Feb 12, 2012 | 05:40 PM
bobfbigman's Avatar
Have you pulled all your connections and cleaned them up? could be just dirty and an easy fix
Old Feb 12, 2012 | 05:57 PM
Mud digger's Avatar
All my connections are spotless, thanks though.
Old Feb 12, 2012 | 06:52 PM
03Powerstroke's Avatar
mine did it when my Alternator was goin bad
Old Feb 13, 2012 | 09:24 AM
Mdub707's Avatar
I would guess alt too. Bring it somewhere and have it load tested! You should try seeing if you have an alternator/battery shop local. They can sometimes just rebuild/rewind your dying one and even bump up the amperage on it too.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
thurobred1320
May 5, 2015 09:26 PM
