03 dodge belt squeeks when i turn motor off?
Old Feb 11, 2012 | 06:09 PM
Madmike's Avatar
Default 03 dodge belt squeeks when i turn motor off?
last week i replaced by serpentine belt and now when i go to shut it off it makes a loud embarrassing squeek ive checked everything all looks good would it be i need to replace my self adjusting tensioner???
Old Feb 11, 2012 | 06:36 PM
H.R.D's Avatar
IIRC this can be as simple as the belt stopping before the motor has completely stopped. Or vice versa...It shouldn't hurt anything.
Old Feb 11, 2012 | 07:28 PM
ThisisDC's Avatar
that is perfectly normal. my truck does it whenever it shuts off too. its because when you shut your truck off, everything that is rotating(crank,pistons,alternator,fan) Everything stops instantly because of the ammount of compresion the engine makes. do not worry about it, its normal
Old Feb 11, 2012 | 08:10 PM
wildbill's Avatar
I believe Genos has a one way clutched pulley you install on your alternator. I do miss that trademark Cummins belt chirp.
Old Feb 11, 2012 | 08:44 PM
torqctd's Avatar
I believe a Goodyear Gatorback belt will cure your chirp.
Old Feb 11, 2012 | 10:21 PM
keepitreal's Avatar
A few seconds of WD-40 while running makes it go away for a little while.
Old Feb 12, 2012 | 12:19 AM
sthrnrider's Avatar
My 01 has does it from day I bought it. My 06 doesn't do it.
Old Feb 12, 2012 | 12:48 PM
00' Quad Cab's Avatar
My 2000 has done it since the day I bought it(on it's 3rd belt now), I believe what happens is the engine shuts down instantly(like stated above) and the fan has some momentum built up and can't stop that quick.
Old Feb 12, 2012 | 01:12 PM
UglyTruck's Avatar
Changing to a GoodYear Gatorback Belt WILL cure it. cured it on my 01, cured it on a friends 04, and on another friends 06.
Old Feb 13, 2012 | 08:59 AM
sthrnrider's Avatar
I like it kind miss it on my 06
