blowby
Old Feb 11, 2012 | 02:58 PM
9512valve's Avatar
Default blowby
so ive been having really bad blowby. people are saying they used valvoline oil and theirs went away. i blew a gasket or something below the heads forgot what its called. and i was told by gillet diesel that i would need an engine overhaul. i would hope changing the oil willhelp i really dont want to rebuild the engine.
Old Feb 11, 2012 | 04:03 PM
H.R.D's Avatar
I don't think changing what flavor of oil you use is going to have any effect on the blow by.
Old Feb 11, 2012 | 04:18 PM
9512valve's Avatar
ya i a couple people said they changed oil and it helped
Old Feb 11, 2012 | 04:23 PM
BOOSTJUNKIE's Avatar
If the blow by is that bad then only a set of rings will cure it. Oil is a bit if a long shot, how many miles?
Banks Monster Ram inlet-BHAF-Pensecola 50hp injectors-Raptor 150 lift pump-GDP Big lines-Banks heater delete-Smarty-BD low pressure light........for now
Old Feb 11, 2012 | 06:21 PM
9512valve's Avatar
236k
Old Feb 12, 2012 | 11:20 AM
ricet07's Avatar
I highly doubt that the oil is going to help enough to make a difference. Even if it does for a little while its like putting a band aid on a broken arm, its not going to make it any better later on.
Old Feb 13, 2012 | 09:05 PM
Gunmetal's Avatar
Change the oil and filter. Use Fram TOUGH Guard TG3976A (a very good filter- don't use regular fram).
Pour in 2 gallons of Rotella and 4 quarts of Marvel Mystery Oil (MMO).
Run it gently for 1000 miles or less then fill with 3 gallons of Rotella 15w40 replace with new TG3976A filter.
Old Feb 29, 2012 | 08:50 PM
jayman54's Avatar
if the vacuum pump is on its way out it will pressurize the crankcase and give massive blow by.. fram is junk...stick with fleetguard or donaldson dont believe me do research filter analysis...
