H1c compressor outlet
Old Feb 11, 2012 | 10:34 AM
artieb's Avatar
Default H1c compressor outlet
I want to build off of a 92 CTD H1C turbo's comppressor, what flange do I need to buy to weld a steel tight 90* elbow on?
Old Feb 12, 2012 | 06:02 PM
cummin_un_glued's Avatar
FormerVendor
why not use a cast 90* and band clamp off of a hx35?
Old Feb 12, 2012 | 06:30 PM
artieb's Avatar
A 90* "air transfer tube" Cummins # 3918685 sweeps about 1 inch too much at 6 3/8th in. Anyone that has done twins fabing has had this issue, I can fab. If I knew I could weld the dirty cast alum, I would cut him down... Anyone welded a factory cast alum piece like this? I just thought if I knew what flange to buy would be best, the v-band is called a 2.75" Thanks for taking a shjot with my problem, Artie
Old Feb 14, 2012 | 10:46 PM
FormerVendor
i've seen plenty of comp housings that have had different flanges welded onto them, i would think welding the elbow would be the same, or i can probably get you one just have to send an email to find out
D-350 dually
9
Feb 11, 2015 12:37 AM
countryboy040993
8
Nov 1, 2014 04:00 PM
