Feel little spit and sputter
Old Feb 10, 2012 | 11:27 PM
1st Diesel's Avatar
Default Feel little spit and sputter
I just changed out injector 7 which was the one giving me all my trouble last night. Took it for a ride and it runs WAY BETTER. I can definitly tell it has all of its horsepower and torque back. runs better when cold, starts better, no more shake when going down the road in the final gear. But my only concern is that when it is cruising at higher speeds i can still barely feel it spit and sputter extremely lightly. could it just be some stiction on another injector maybe? i'm doing an oil change tomorrow and last night ordered my first two bottles of Rev-X. should be here by thursday. think this is possible to clean it up and keep it from doing that?
also does anyone know why in the H3LL is it whenever i go to shift from park into reverse or drive i have to bury the brake into the floor to get it out of park and other times i can barely tap it and it shifts out of park no problem?
Last edited by 1st Diesel; Feb 10, 2012 at 11:27 PM. Reason: Automerged Doublepost
Old Feb 11, 2012 | 11:14 AM
bobfbigman's Avatar
I'm thinking you have a little stiction going on, if it is like you describe I think the Revx is going to do the trick. The issue with the shifter is most likely just a linkage under the dash, should be able to adjust it or tighten it up to fix your problem.
Old Feb 11, 2012 | 02:23 PM
1st Diesel's Avatar
Awesome ok. Thank ya bro. Hoping the Rev x helps. I can feel at idle right now it is having a small misfire.
