24v fuel economy crap. need valve adjustment?
Old Feb 10, 2012 | 03:24 PM
starrysky111's Avatar
Default 24v fuel economy crap. need valve adjustment?
so im getting like 15-16 highway mpg in 6th gear at 68mph from what ive read thats crap so whats wrong? getting plenty of fuel now with the airdog and the comp box is set on 3. i started reading about valve adjusting and the trucks got 190k. not sure if its ever been done. is that something to look into and will that help my mpg of they are out of adjustment? thanks
Old Feb 10, 2012 | 03:40 PM
00' Quad Cab's Avatar
Wouldn't hurt to slip some feelers in them valves and adjust them, I didn't really notice a mileage change after I did mine.
May need to reset the APPS, that may help or it could just be the winter fuel blend.
Not sure where you are located but I know I get worse mileage in the winter do to the winter blend fuels. Ultra low sulfur diesel has also had a negative affect on mileage.
Old Feb 10, 2012 | 04:00 PM
H.R.D's Avatar
Easiest way to find out if it will help you is by doing it.
Below are some pdf files that can help you a lot on resetting your APPS and Overhead.
File Type: pdf
File Type: pdf
Old Feb 10, 2012 | 04:19 PM
sthrnrider's Avatar
When I did mine I didn't notice any change in MPG.
I am here:
Old Feb 10, 2012 | 04:31 PM
H.R.D's Avatar
Originally Posted by sthrnrider
I am here: Google Maps
is up with the map?
Old Feb 10, 2012 | 05:21 PM
sthrnrider's Avatar
I'm posting from my phone I don't know why it does it. It might be the tapatalk app IDK
I am here:
Old Feb 10, 2012 | 06:19 PM
H.R.D's Avatar
Never had that come up with my tapatalk. But then again you may have a featured turned on that I don't.
Old Feb 10, 2012 | 07:27 PM
sthrnrider's Avatar
I'll look in to it
I am here:
Old Feb 10, 2012 | 07:32 PM
sthrnrider's Avatar
Is this better HRD
Old Feb 10, 2012 | 08:03 PM
turbo20psi's Avatar
What gears are in the diffs.?
