P1689 2001 24v????
Old Feb 8, 2012 | 06:38 PM
BOOSTJUNKIE's Avatar
Default P1689 2001 24v????
Hi all,
Whilst out in the truck tonight I started to roll on the power and build boost up a slight incline in 4th, the truck shut down for a second then came back, then shut off again, engine light came on.
I was gentle on the loud pedal for a bit then tried again and all was fine ! So obviously it's a bit intermittent.
The only code was P1689 which is communication between ECM and pump I think??
When I got the truck that code was stored but I cleared it and no further problems till now.
Am I right in thinking my poor VP is dying ????
Any thoughts appreciated
Cheers
Paul
Old Feb 8, 2012 | 06:48 PM
wildbill's Avatar
Bosch VP44 Diesel Injection and Lift Pump for the 1998.5-2002 Dodge Cummins Diesel VP 44
Old Feb 8, 2012 | 07:07 PM
Well I've got a raptor 150 and GDP big lines so im pretty convinced that fuel supply is good enough, however the damage could have been done before I got the truck and fitted all the mods??
The truck has 255k on the clock and I don't know if it's the original VP, any way of telling?? Is it just a case of being worn out??
Old Feb 8, 2012 | 07:23 PM
The Smarty wouldn't cause the pump to fail prematurely would it???
Banks Monster Ram inlet-BHAF-Pensecola 50hp injectors-Raptor 150 lift pump-GDP Big lines-Banks heater delete-Smarty-BD low pressure light........for now
Old Feb 9, 2012 | 08:17 AM
jedder21's Avatar
my comp caused me fits similar to that it caused a fuss for about a week and all of a sudden gone no trouble from it at all there is a good chance your having chip troubles is there a yellow tape on the buss plug on the vp that has void written on it if that is not broken good chance your vp is original thats my .02
Old Feb 9, 2012 | 02:05 PM
I remember seeing the void sticker, I think it has been broken but maybe someone has been playing before my ownership.
Driving the truck today it started to become more frequent so I'm thinking the VP ecu is dying. !
Old Feb 9, 2012 | 05:47 PM
jedder21's Avatar
maybe try pulling the smarty and if no improvement then good chance you might have a bad vp
Old Feb 9, 2012 | 06:16 PM
I set it back to stock map this morning with the hope of getting rid of the issue, it still reared it's ugly head but not as often. So I think I've got VP issues.
It must be where the smarty is making the pump work harder so showing the fault more often .
Any thoughts on where the best place is to get a new VP???
Need somewhere that is happy to ship it to the UK, more expense !
Old Feb 10, 2012 | 08:18 AM
jedder21's Avatar
that sounds like your on the right track as to where to get one i got a remanufctured oem one through a local cummins shop being in the uk if you have a shop that can do it that may be a good option but you could maybe post a new thread asking where a good place to go through i know some of our members are venders as well hope that helps.
Old Feb 10, 2012 | 07:16 PM
Sounds like a plan fella, cheers
