DIY Upgrades?
Old Feb 7, 2012 | 12:31 PM
Truck Guy99's Avatar
Default DIY Upgrades?
What are some good DIY upgrades for free or cheap (Maybe $100)? One of my favorite mods is removing the turbo silencer ring and straight pipe exhaust. The truck I am considering purchasing is a '91-'93 1-ton dually 2wd auto. I know I can also move the fuel plate a little and a nice aftermarket air filter, but what else? Thanks in advance for any help or advice!
Old Feb 7, 2012 | 07:52 PM
ricet07's Avatar
Well unless the truck has been converted to a p pump there is no fuel plate. Look in the sticky on tuning your VE Pump and read up to learn how everything works. Make sure you get some gauges before you go playing with it too much. Anyways with the ve pump the best and cheapest mods are a 3200 gov spring, upgraded fuel pin (Denny T) or turn your stock one, timing bump 1/8" and some turns on your fuel screw. Then tune your afc with the starwheel.
Old Feb 8, 2012 | 08:50 PM
dieselz's Avatar
I agree with ricet07. just doing those mods makes a differance.
Old Feb 16, 2012 | 01:57 PM
Thanks eveyone!! Anyone else?
Old Feb 16, 2012 | 03:29 PM
db Zac's Avatar
buy a pryro gauge before doing ANY fuel mods. You will be surprised how easy it is to run you EGT's to hot
Old Feb 27, 2012 | 01:05 PM
That was already in the plan, I just forgot to mention. Anyone else?
Old Feb 27, 2012 | 02:37 PM
moparbubbabt59l's Avatar
Cut up your stock air box and remove the metal mouse trap ir make a bhaf. For a little more the $100 id get an m&h dynamic timing spacer. And ofi has a lp lift pump in the $150 range
Sent from my DROIDX
Old Mar 1, 2012 | 06:45 PM
Thanks! Anyone else?
Old Mar 1, 2012 | 08:08 PM
tiremann9669's Avatar
When you do the straight pipe go 4'' or 5''
Old Mar 9, 2012 | 01:18 PM
Question
Why?
