Power power and more power
Old Feb 5, 2012 | 11:09 AM
Colton Carter's Avatar
Default Power power and more power
I have a 12 valve 96' totally stock and I want to know what can I do to make the most pulling power
Old Feb 5, 2012 | 11:11 AM
Start off with a good set of gauges and an exhaust system.
Luke
Old Feb 5, 2012 | 11:14 AM
Okay. I'm getting pyrometer boost and trans temp phantom ll guages. Then I'm getting a 8" miter cut stack. Then what?
Then getting a AFE air intake
Last edited by Colton Carter; Feb 5, 2012 at 11:14 AM. Reason: Automerged Doublepost
Old Feb 5, 2012 | 11:48 AM
tower_ofpower's Avatar
Gov springs and a lift pump upgrade, alot of guys go for the things that add power but neglect the supporting mods. 3k gov springs are fine on stock valve springs, 4k's you at least need the 60# valve springs. Upgrade your overflow valve too, heard of guys picking up 25 horse just from properly maintained fuel pressure which the bosch OFV is sub par at. After that, take it to a shop or do it yourself; but bump the timing. Boost elbow THEN add yourself some fuel. You'll find the gains much more pleasing this way
Old Feb 5, 2012 | 04:35 PM
Mr. August's Avatar
KDP so your truck dont explode
Old Feb 8, 2012 | 11:02 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Transmission will need help with all the added power!!!
