After a LP hard start
Old Feb 4, 2012 | 08:04 PM
95taylor331's Avatar
Default After a LP hard start
My friend has a 98 24v and the stock LP took a dump so he put a 100gph carter on it and took the fuel line strait from the carter to the fuel filter housing and bypassed the stock LP and now it starts hard, Any Ideas??? we checked for any possible air leaks and we cant find anything that would be causing this
Old Feb 5, 2012 | 11:31 AM
cummin_un_glued's Avatar
FormerVendor
how does he have it wired in?
Old Feb 5, 2012 | 12:09 PM
00' Quad Cab's Avatar
X2 if he doesn't have it wired in to be controlled by the ECM he could be over pressurizing the VP which will make for hard starts.
Old Feb 8, 2012 | 08:54 PM
He wired it in using the stock LP power source
Old Feb 9, 2012 | 08:32 PM
FormerVendor
just for grins try a different lift pump like a stock carter....we have seen more then a few cases with the airtex replacement pumps cause a hard start, after talking with bosch about the problem it seems that the ecm calulates the pressure by reading the amp draw on the lp circuit and the pumps are not drawing the same current and it sends a false signal to the ecm and causes a hard start, i've even heard of this problem with the fass direct replacement pumps but i think they have since fixed theirs
Old Feb 12, 2012 | 09:57 PM
Ok wil try that, Thanks for all the help man! I greatly appreciate it!
Old Feb 12, 2012 | 10:46 PM
FormerVendor
no problem, let me know if that changes anything
Old Feb 12, 2012 | 11:05 PM
mysterync's Avatar
A hobbs oil pressure switch will bypass the ecm. That's the first time I've ever heard the ecm makes pressure calculations according to amperage draw speculation.im going to do some research on that subject. Considering the variables it would be difficult at best but in the same respect I rarely use factory fuel systems or ecm/pcm wiring.
Sent from my DROID BIONIC using Tapatalk
Old Feb 18, 2012 | 09:54 PM
FormerVendor
i didnt get to talk to bosch myself but the injection pump shop that i get my vp44s from did talk to them directly for me while we were trying to figure out a hard start condition on a truck which we had just replaced the injection pump on and that was the answer that we got from them, since finding this out we have fixed half a dozen other trucks that were having similar problems and all of the trucks had the airtex pumps on them and the only thing we done was swapped them back to the OE carter pumps and their problems went away. it was the first time i had heard about this amp reading to pressure also but after hearing that and thinking about it then it did make some sense to me since there is no fuel pressure sensor anywhere yet you read on the forums all the time that high pressure will cause a hard start. i do know of one truck that is running a mechanical lift pump at 35psi yet he dosnt have a hard start so if the ecm was reading the actual pressure somehow then that truck should have a hard start and it dosnt, and yes i know that much pressure can crack the diaphram in the pump and i did advise him to regulate the pressure down below 20psi
mystery maybe you can shed some more light onto this subject it would be some good information for everyone, i wish i knew more about it but that is the extent of my knowlege on the subject since i didnt get to talk to them myself
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
