4th Gear Limp Mode
Old Feb 4, 2012 | 03:20 PM
Gun's Avatar
Gun
Default 4th Gear Limp Mode
Hi guys. I am having an issue. My truck is acting up. When I start it the only gauges that work are oil pressure and voltage gauge. Everything else is on zero. Prnd321 also not lit. When shifting from park to reverse or drive it snaps and truck lunges. I only have 4th gear. Engine will rev past 2000 rpm just won't shift. I have no DTC's when I scan. Replaced NSBU with no change. Any ideas?
Old Mar 7, 2012 | 08:40 PM
QuickCarl's Avatar
I've had that issue on a few 01s and a few 03s. The problem on all of them was the neutral safety switch and both connector pig tails. I replaced all three components from GM and that corrected the issue on all of them. Another thing that I have heard about but haven't witnessed yet is a gound wire on the left frame rail under front of cab needs to be cleaned.
Old Mar 7, 2012 | 10:59 PM
2004LB7's Avatar
mine wasn't that bad but cleaning the ground QuickCarl talks about helped. there is also a DIC fuse in the fuse box. you could try that for your cluster
ClintD.
Apr 30, 2015 09:38 AM
6.4 king ranch
Ford Powerstroke 08-10 6.4L
Apr 15, 2015 03:53 AM
ClintD.
Chevy/GMC Duramax 06-07 LBZ
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
To fast
Chevy/GMC Duramax 04.5-05 LLY
Feb 10, 2015 09:30 AM
