EGT's ?
What is a normal EGT reading with a silver 64/74/14 with 200 hp injectors ? around 35 mph and then easin into at 15psi im starting to see 1,000 degrees cruisen down highway 65mph at 1 pound of boost like high 700's soon as turbo starts to make boost the egt spikes up to 1200 plus and what may cause this a Bad injector ? when i first put the turbo on never seem to spike that high its been sitting for 3 weeks why i been out on the Road cause i drive a truck for a livign i get back thursday night drive friday afternoon take it out and it seems not be right to me with egts getting that hot that quick..
Sounds normal to me. What are your EGTs when the turbo lights up. I know with my 62 when it lights up my EGTs go down but I'm running stick injectors. 1200 ain't that bad its getting in the 1500 or more range and staying there is what hurts the turbo. Look over your boots make sure you don't have a leak. But IMO everything sounds normal.
I am here:
I am here:
HEY well thanks Sthrnrider for the reply back..... when i light up and its gets up around 1300 plus... i did find a problem last night turbin house on the front is leakin i seen black soot all on the back of my compressor housing but the hold down tabs and the bolts where all tight ... i know notice i cant get over 40 psi i can only hit 39 and 40 and waste gate isn't hooked up
To me the EGTs sound normal for your set up. I would buy a rebuild kit for the turbo get it all sealed up good. Keep in mind if your running stock intercooler boots with that turbo you might bust one. It happened to me I put on BD boots. Your only hitting 40 psi? With your set up you should be pushing 50 if you have head studs. Mine is setup for 43 psi haven't hit it yet but when I but new injectors it will be no problem. With stock injectors I can hit 38 psi with my current setup. The weather can affect your boost as well on cold days it will build more boost than normal on hot days no as much.
I am here:
I am here:
