slipped timing???
Old Feb 3, 2012 | 02:43 PM
cumminskid92's Avatar
Default slipped timing???
Is it possible for the VE to slip timing. i know it is a problem for the p-pump guys. my truck started to smoke and run rough when i start if after it has been sitting for awhile. i know it sounds like it is bleeding back fuel but it will also stutter a little if i rev it up no matter how long i have been driving. it just seems like the timing is retarded to me. i runs great when driving.
oh also if i start it and start driving right away before it stops running rough and smoking it will clear up almost immediately. could my KSB be bad
Last edited by cumminskid92; Feb 3, 2012 at 02:43 PM. Reason: Automerged Doublepost
Old Feb 3, 2012 | 06:38 PM
kieron_kohlmann's Avatar
nearly impossible to "slip" timing
Old Feb 4, 2012 | 12:21 PM
chrislib's Avatar
I`d say 100% impossible, unless there is major carnage/breakage as the gear on a VE is keyed to the shaft. Sounds more like low lift pump pressure/ dirty filter or an air leak somewhere in the fuel lines.
quiksilver1j
Jul 30, 2015 12:41 PM
sparrow118
Jun 22, 2015 05:03 PM
Stox5225
22
May 14, 2015 05:17 PM
SMatyac
Nov 15, 2014 07:35 PM
91 7three
Nov 14, 2014 10:37 PM
