High hp turbo help
Old Feb 2, 2012 | 08:12 PM
12vRambo's Avatar
Default High hp turbo help
Still running the stocker right now but i was just wondering for a 900+ hp streetish truck what kinda size/brand twins would work nice. But here is the catch, i want to run the smaller turbo as a single until I need/can afford twins. Im really tempted to get a 66mm silverbullet as a single but that would obviously be way too big in a twin setup. Then thought maybe get a 62mm SB cuz it would spool nice but then im lost on the large turbo?
Any help/criticism would be appreciated.
Dennis
Old Feb 3, 2012 | 01:46 PM
94 12valve's Avatar
900+ on fuel? or on the juice
Old Feb 3, 2012 | 02:47 PM
12vRambo's Avatar
My personal goal was a 1000hp fuel only street truck. I realize my goal is somewhat "ambitious" and I have read enough forums on here to know it wont be cheap or easy but this is a long term project. I know that almost everybody on here will tell me it cant be done for a street truck but I still think it can be done. All that aside the direct answer to your question would be fuel only.
Dennis
Old Feb 3, 2012 | 06:11 PM
94 12valve's Avatar
tripples would be my answer to your question than. A set I would love to try if I had the truck/money/time is ... Start with a 66/73/.9T4 off the manifold with one of sdx's spool flanges, along with a good size external gate, two 64/71/.9t4 atmosphere chargers feeding the 66 with a external gate on the header. Gonna be a fair amount of plumbing with the flange and gates but it should spool quick and make some power with other supporting mods.
Tripple 63's have made 900+ on some cr's
Old Feb 3, 2012 | 06:19 PM
12vRambo's Avatar
I dont really think im a fan of tripples. The route i was gonna go was silverbullet 62 with a s475 or something like that. I would first use the 62 as a single and then upgrade to twins. The part that im unfamilliar with is the larger s-framed turbos. Any help there?
Dennis
Old Feb 3, 2012 | 06:21 PM
94 12valve's Avatar
Dennis
If you wanna do twins 64/71 off the manifold is what I would start with, as for the primary the s478/92/1.1 a/r t6 gets my vote
Old Feb 3, 2012 | 06:26 PM
12vRambo's Avatar
Care to share your reasoning behind your choice?
Old Feb 3, 2012 | 06:29 PM
94 12valve's Avatar
the 64 has been the popular choice for singles on 12v's for a while, its just a good combo with that turbine wheel. as for the primary the 478's are more $$ than the 475's with a 96 turbine but they will spool faster and flow more air.
Old Feb 3, 2012 | 06:42 PM
12vRambo's Avatar
Just for the sake of arguement why not something like a 62 with a s480 ?
Old Feb 3, 2012 | 06:49 PM
94 12valve's Avatar
you could, but that 480 is very lazy on the bottom end. the 62 is a good charger but the 64 is better, spool up with either the 62 and the 64 is very close.
