Coolant?
Old Feb 2, 2012 | 09:08 AM
EricC's Avatar
Default Coolant?
What coolant should I use after doing my egr and oil cooler?
Old Feb 2, 2012 | 09:55 AM
Arsenal's Avatar
Ford gold is fine or any other Extended Life Coolant...need someone to chime in on what chemical it should be based on. I know one of them is no good for these but i cant remember which
Old Feb 2, 2012 | 10:00 AM
COLETRA1N's Avatar
chemical flush it with vc9 or restore and put ec-1 rated ELC coolant in and you will be set
Old Feb 2, 2012 | 10:23 AM
EricC's Avatar
Do I have to take the starter off to do the coolant??
Old Feb 3, 2012 | 01:13 AM
brondondolon's Avatar
A few weeks ago we had a long discussion on coolant look for a thread by mdub "coolant discussion"
No you don't need to take the starter off. There are two drain plugs on the block. Removing one will suffice.
In a thread by me "what coolant to use" at the end is a link to the most discriptive write up ive ever seen on how to properly flush it
Me personally I'm a huge advocator of delo elc concentrate rotella elc concentrate, fleetguard elc concentrate, and catipillar elc concentrate. I have no faith in Ford gold or zurex being as the proof I've seen of them clogging the oil cooler and the egr cooler due to the silicate goo they leave.
Things you will need:
4 gallons of elc concentrate (your choice brand)
28-35 gallons of distilled water (for flushing)
4 galons of distilled water (to mix with elc concentrate)
Fleetguard restore
Flrreguard restore plus or 2qt of Ford vc-9
Thermostat (optional)
Old Feb 3, 2012 | 08:32 PM
EricC's Avatar
Well i have nearly got everything i need Got egr kit got oil cooler got inteak gaskets, coolant filter, recon cab lights just have to get the coolant and the oil and filters. thanks alotof freaking water to have to buy!!!
Old Feb 3, 2012 | 10:38 PM
i paid like 60 cents a gallon at wallyworld so it comes out being prob the cheapest part haha
you dont have to do it that way though its just what ive been recommended and from what ive heard its a long process which is why ive been putting it off haha im supposed to do it tomorrow but then again i was supposed to do it today haha
how many miles are on the coolant thats in there right now?
here is the link i was talking about hope it helps
http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
Last edited by brondondolon; Feb 3, 2012 at 10:38 PM. Reason: Automerged Doublepost
Old Feb 4, 2012 | 09:05 AM
EricC's Avatar
I only have maybe 5k miles on it. I had it flushed not to long ago and got ford gold in it now
Old Feb 18, 2012 | 02:40 PM
jimrd's Avatar
i am flushing my 2005 today
the coolant was green
pulled the bottom hose and drained
put hose back on and put the Ford vc9 in (two bottles) topped up with distil water
run truck for one hour
removed bottom hose
filled up with distil water
run for 20 min
Dump again
put hose on and put in the Cat ELC red coolant in
The Cat coolant sells for 15.89 jug
The Kenworth coolant 10.86 jug
The Cat dealer told me the fluid is made by same manufacture ( different label)
go accross the street and get it there...he even phoned over at the desk to get me the discount
Nice
Old Feb 18, 2012 | 07:11 PM
ranger518's Avatar
cat-1 ELC and if you want to drain everthing out yes you will need to remove the starter. i just flush 2-3 times after i flush everthing with distiled water and pull the driverside plug out. and then fill with 100% antifeese to get my 5050 i think the passanger side of the block holds about 1 1/2 gal.
