Finally found a code. Anyone ever have same one??
Old Jan 31, 2012 | 07:02 PM
1st Diesel's Avatar
Default Finally found a code. Anyone ever have same one??
Code is P0279. It's Cylinder 7 Injector Circuit Low. Anyone ever have this code and figure out what exactly it was or how to fix it? Only code found. Mechanic did tests on EVERYTHING for the truck and this was the only one found. Tested engine, trans, turbo, everything literally. 03 F250 6.0L CC SB FX4. only mod is 3 1/2 straight pipe with a turn down behind the cab. . any help or suggestions appreciated.
Old Jan 31, 2012 | 07:21 PM
Karls03's Avatar
Cylinder 7!?! Man, I popped 1-8 when my FICM was puking! AFTER #8 was replaced.
But seriously, I had a code on number 8 injector when it stuck open. It was complete with that gasser V-8 "plug wire off miss" in the exhaust tone. I'm pretty loose with someone else's money, so I say change number 7.
Old Feb 1, 2012 | 07:45 AM
Mdub707's Avatar
Yeah, probably need to replace injector #7. This is the ONLY code?
Old Feb 1, 2012 | 08:50 AM
1st Diesel's Avatar
Only code. I had one come up for crruise control but we didn't hit it when the scanner said to. I've used the cruise before to test it and it works fine.
I had a p0281 l that we found but it was just in the old memory and it never came up when doing any checks. Just wanna throw that out there
Old Feb 1, 2012 | 10:21 AM
Mdub707's Avatar
Yeah, probably injector #7. If you had some good spares I think you could technically just swap the electronics on the injector too, but sometimes that's more trouble than it's worth.
Old Feb 1, 2012 | 12:23 PM
1st Diesel's Avatar
Ok. Lol. Yea I am just gonna tear into it and replace it and do new o rings. Then change the oil, run synthetic and add 2 bottles of Rev x to freshen her up
Old Feb 1, 2012 | 12:31 PM
Mdub707's Avatar
Sounds like a good plan of attack.
Old Feb 1, 2012 | 01:25 PM
1st Diesel's Avatar
What's some good brand of synthetic to run in these motors?
Old Feb 1, 2012 | 02:03 PM
Mdub707's Avatar
Rotella 5w-40 T6 is popular, Amsoil's is pretty popular, as well as Valvoline premium blue 5W-40.
Old Feb 1, 2012 | 07:11 PM
1st Diesel's Avatar
Awesome. Thank ya for the heads up on that sir
