buying a new 2000 2500
hey all im about to go look at a 2000 dodge 2500 with the cummins and a auto tranny. anything i should look for? o new tranny, rear end driveshaft etc. o and has 150000 on it what are common problems on these things? thanks tim
Is it 4wd or 2wd? The front end usually wears out. The drum brakes in the rear are a pain so make sure the truck stops well and the e-brake works. You can look at the VP44 wires to see if the wire was ever tapped for a programmer. Oil and power steering leaks, blowby, dash cracking and poor stock fueling (lift pump) are a few more I can think of at the moment. Take it for a ride and make sure the throttle is smooth and you do not have a deal pedal. Warm it up and see what all is leaking. Check all the fluids because the seller may run them low to reduce the leaks.
Also slip it into 4x4 while on your test drive and make sure it stays in, if the 4x4 light in the dash flickers then you have vaccuum issues and will lead to stipping the splines on the front axle shaft cuz it dont engage the CAD all the way. (you may want someone to watch it as you drive) another way to check the vaccuum pump is to make sure it stays on floor heat or vent and not go to defrost at an idle.
so how do ya check fuel pressure in this i dont have a test guage. also this is the first truck i am lookin at that hass a turbo how do you test blow by? what is blow by? also with the front end ya just mean lock it in 4x4 and gas it make sure all 4 tires spin? and can ya explain that vacume pump test again with the heat and defroster?
if there is a casted 53 on the drivers side of the block under the injection pump it is probably going to crack were the water jacket is due to lack of nickel when it was manufactured and check out the VP44 real good other then that they are nice trucks how much is he asking
I bought a 01 4x4 2500 with 150,00 on it,i have replaced the tranny,whole front end,ball joints track bar,hubs,tie rod's,and put a steering box stabalizer on it,also new steering stabalizer.If u can make sure u roll down a road a highway or something around 70 75mph and hit some bumps!!!! I test drove mine b4 i bought it and had no idea it had the dreaded death wobble!!!! I only got up to like 55mph on the test drive didnt know anything was wrong when i drove it. About crapped my pants the first time it did it!! other than that i luv it now!!!! drives like a caddy!
Front ends (4x4) hope the best on the trani
