ve to p-pump conversion
Old Jan 30, 2012 | 10:30 AM
Gitrdun199's Avatar
Default ve to p-pump conversion
I have a ve pumped non-intercooled truck and also have a p-pumped 12v if what ive read is correct i can swap everything over to the ve block but i have heard the injector inlet is different on the two truck? Any ideas?
Old Jan 30, 2012 | 12:52 PM
ricet07's Avatar
Yes look in the stickey, there is a write up in there. The injectors on the non I/c trucks were 9 mm and the I/c trucks were 7 also different spray pattern iirc. The pop pressure is too much for either of the first gen injectors anyways.
Old Jan 30, 2012 | 03:51 PM
Gitrdun199's Avatar
but there is an adapter to change sizes for the non intercooled?
Old Jan 30, 2012 | 07:00 PM
ricet07's Avatar
Yes there is bushings/shim to run 7mm in a 9mm head. Here is an old thread to read through. https://www.dieselbombers.com/1st-ge...-together.html
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
Andrew1995
Wanted To Buy (WTB) - Used
Feb 25, 2015 03:44 PM
bonestock
Feb 1, 2015 08:41 PM
