Clutch Help
Old Jan 28, 2008 | 01:24 PM
Buckshotmckee's Avatar
Sma't Alec!
Question Clutch Help
I'm going to be looking for a new clutch for the 06 in the next 6-8months and was wondering what your guys thoughts were? I had the South Bend Con OFE in my 02 and it was awesome! Peter over @ South Bend was great! My goal is 550hp. I use the truck mainly for towing and I want something nice and smooth that will hold the power! Thanks guys!
Old Jan 28, 2008 | 02:05 PM
STROKER400's Avatar
This is what I have learned. You can go with a double disc that will hold alot of hp and will hold up if you sled pull but this clutch set up requires a $ 250 hydrolic kit But the con ofe single disk is good for 450 hp and more i am told but if ya slip it, it wont weld togeter. The con fe is a diff meterial then the ofe and if you slip that clutch bad it may weld it self together and you wont be able to push your clutch in. I am plaining to go with the con ofe and i will probley be in the 480 500 hp range also. and these to single dick clutches will have the same fell as the stock clutch.
This is just my 2 cents. all these are south bend
Old Jan 28, 2008 | 02:09 PM
Sma't Alec!
I'm seriously think'n bout going back with the OFE but not sure if it will hold the extra hp?
Old Jan 28, 2008 | 02:17 PM
STROKER400's Avatar
What i have been told it will hold a good amount. The double disk are sweet but alot of money a hard pedel also.. The con fe is a bit more hp but i dont like it if you slip it bad I have seen bad ones but they are sled pullers.
Old Jan 29, 2008 | 08:07 PM
Sma't Alec!
Hmmm!!!! Nobody else???
Old Jan 30, 2008 | 09:01 AM
staarma's Avatar
I have the CON FE right now but will be going to a DD this Spring. I'm slipping the FE now and I'm afraid it's only a matter of time before something bad happens. A lot of guys are going with the 3200 DD street version. It is being talked up quite a bit. I would call SB and talk to them over there. They can recommend something for you that makes sense based on your goals. My goals changed midstream so it will cost me more money but that's the way I usually operate. Buy high and sell low and try to make it up in volume.
Old Jan 30, 2008 | 09:11 AM
Whit's Avatar
Site Mascot
How much HP/TRQ does it take to slip a FE then????
Old Jan 30, 2008 | 10:27 AM
staarma's Avatar
Well, the last time I dyno'd I had 607 HP and 1189 TQ. Now, I have a new IC and I replaced the HTB2 with the HTT 62/71/13 ss and added a Diablosport programmer along with the straight through Donaldson instead of the baffled Donaldson. I haven't dyno'd this combo yet but it is enough to slip the clutch now.
Old Jan 30, 2008 | 10:30 AM
Whit's Avatar
Site Mascot
impressive numbers and good clutch info
Old Jan 30, 2008 | 10:47 AM
STROKER400's Avatar
I assume that is with a con fe then? So the con ofe probley will hold some good numbers too.
