EGR Delete
Old Jan 29, 2012 | 04:51 PM
Michael Sands's Avatar
Default EGR Delete
I have been looking to put a EGR delete kit onto my 6.0 is this a good idea and should new intake gaskets be put on. who sells the best kit thanks
Old Jan 29, 2012 | 07:08 PM
jeffa6980's Avatar
Pretty much all of them are good kits. I used mkm cusomts. I didnt use new gaskets. i just loosened the intake manifold some and pried it up to pull the egr cooler out. And the egr delete is a great idea for the 6.0. good luck and ask any more questions you have.
Old Jan 30, 2012 | 07:32 AM
smoke eater's Avatar
How are your delta's if they are 15edeg's or more you need to replace your oil cooler as well but make sure you flush the system the right way with restore and restore + before you replace the coolers or they will plug up quickly and you will be doing it again. I used this one off of e-bay it is a verygood kit so why spend more money 6.0L FORD F250-350 UNF DIESEL EGR VALVE DELETE KIT (794504110203) | eBay I also replace the intake gaskets , I figured that I would just get the thing out of the way and not have to worry about it. Which ever way you go be carefull of the injector clips and do not loose them. Not sure where yours is on a 03 but on my 05 when I did my cooler and delete I unknowinly know the plug loose to the IPR on the back of the motor and created a no start issue and had to tear it down again, just a suggestion. Good luck and wellcome to the 6.0 world
Old Jan 30, 2012 | 02:59 PM
Mdub707's Avatar
I used new intake manifold gaskets every time I take it off. Ford does say they are reusable though. I did my delete around 80k miles and my gaskets could have easily been reused. I did a buddy's 04 that had 100k miles on it, and no way could we have used them again, the rubber o-rings had deteriorated.
Old Jan 30, 2012 | 05:28 PM
Thanks for the in have ordered the Delete kit from ebay and have picked up the gaskets from parts store i went ahead and got the upgraded oil drain tube and new ICP and going to do the zoodad mod this weekend with a friend thats for all the help i will let you all know how it goes
Old Jan 31, 2012 | 08:22 AM
Mdub707's Avatar
Sounds good man!
Old Feb 9, 2012 | 02:22 PM
2006f250's Avatar
What is the advantage to doing the EGR delete and the coolant filter? Just curious
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Bighouse
Apr 9, 2015 06:51 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
Shmeldon22
Ford Powerstroke 08-10 6.4L
Dec 14, 2014 11:22 PM
