Air Bags
Old Jan 29, 2012 | 12:42 PM
Olgraymare's Avatar
Default Air Bags
Like many I am looking to soften a 1st gen ride. I have glanced through the forms and it seems that softer springs arn't the way to go, but air bags might be. Any thoughts or garunteed solutions? anyone have a good source for airbags?
Old Jan 29, 2012 | 04:07 PM
sweetv8s10's Avatar
I had air bags on a 1 ton and it didnt help at all.
Old Jan 29, 2012 | 07:14 PM
white93's Avatar
I have some on mine. Empty, You won't feel most of the small bumps but the bigger ones you feel more. Loaded, You don't buck as much but its still not a smooth ride.
Old Jan 29, 2012 | 10:19 PM
1STGENFARMBOY's Avatar
The only way airbags would soffen the ride, would be to get rid of all the leaf springs and replace them with a compleat air ride suspention.
they are made to help out with more load not to make it ride better.
Dar
Old Jan 29, 2012 | 10:49 PM
tower_ofpower's Avatar
Dar
Don't have to remove every leaf... That'd require links to stabilize the rear axle. Remove a few leafs and use the air bags to compensate for the loss in spring rate. Shocks will make a world of difference for your ride. Personally I think air bags need a better shock as the oscillations can be a little more violent. Takes less to set things into motion. Steel being a little more "stable" although due to mass it's harder to control. So, stock shocks can add to ride discomfort just because they were meant to control the action/reaction of leaf springs.
Old Jan 29, 2012 | 11:18 PM
sweetv8s10's Avatar
If u want a smooth ride u could always buy a car
Old Jan 31, 2012 | 03:00 AM
jwirth's Avatar
Love it
These trucks ride rough??? I guess after driving 18 wheelers you don't notice it
Old Jan 31, 2012 | 09:50 AM
Olgraymare's Avatar
Default thanks.......i think
LOL on the car comment, I don't mind running roads but I check a trap line every morning on 15 miles of almost 4wd road. I have become accustom to removing my hat so I dont poke a hole in my head from the hat button when my head hits the cieling. I think I'll try removing the 2nd and 3rd spring and add bags.....I'm just talking on the rear here.
Old Jan 31, 2012 | 09:59 AM
Edahall's Avatar
You want to remove enough springs such that the height is reduced several inches. You then use the air springs to get the height back.
The same can be accomplished with the front as well.
Air Lift Company
AirLift
Sep 25, 2015 09:13 AM
Air Lift Company
AirLift
Aug 12, 2015 03:10 PM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
six speed
Nov 30, 2014 09:02 PM
