Starting
Old Jan 28, 2012 | 09:26 PM
ricet07's Avatar
Default Starting
Truck starts but almost have to run it like a old carbureted gasser, have to hold 1/4 throttle and fires right up and then idles fine. Just wondering if this could be as simple as adjusting the fuel shut off solenoid rod? Didn't want to go tearing into anything until I got some input.
Old Jan 28, 2012 | 10:01 PM
Heavyhaul07's Avatar
What is your idol at should be 750-850 in gear with ac on. Some trucks are that way
Old Jan 28, 2012 | 10:15 PM
ricet07's Avatar
It is alittle on the low side, no "in gear" check do to it being a 5 speed but it is only at 600 w/ ac on.
Old Jan 28, 2012 | 11:33 PM
mikerumsey's Avatar
Is it only until it fires and idles for a few because i had a 95 12v that did the same thing but that was because it was dumping enormose amounts of fuel.. is yours trned up?
Old Jan 29, 2012 | 12:11 AM
ricet07's Avatar
Yea just until it fires, then it idles on its own fine, stock injectors but fuel plate is custom ground.
Old Jan 29, 2012 | 07:43 AM
beardog78's Avatar
A lot of guys run a choke cable or some kind of cable from throttle linkage to the inside the truck so you can warm it up a little better. I had the same problem but i looked into it and found i had a wire loose on my fuel heater. I hooked that back up and it took care of the problem.
Old Jan 29, 2012 | 11:43 AM
mikerumsey's Avatar
Id say nothing abnormal there should only do it when it cold tho not all the time..
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
gunman41mag
The Sportsmen's Lounge
Jul 1, 2015 10:21 AM
Squirt
Jun 19, 2015 12:40 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
